Loud moaning sound and wind up sound
140,350 MILES • AWD • AUTOMATIC
JLFUERST
I have been noticing a moaning sound when turning. Then this morning it was cold and as I went to drive away there is a loud moaning sound and a loud noise that sounds like the car is winding up when I pushed on the gas. I just got my oil changed and transmission fluid filled last night and the noise stopped. Then this morning it was worse please help
Feb 11, 2016 at 12:49 AM
JOHNNYT73
  • 924 POSTS
In these vehicles its pretty common for the rack and pinion to fail. Check your power steering fluid level. If that is good then I would suspect a bad rack or pump. Take it a shop to have them diagnose if it is the power steering pump or rack and pinion.
Feb 11, 2016 at 12:56 AM
