It would help if you uploaded a picture or a short video of what you are talking about but in the meantime, here are images and information on what I think you are talking about.
1. Remove engine compartment vertical cover.
2. Pull fan cover ring pins rearward, then turn ring to lefthand side to remove.
3. Install special tool No. 104 589 00 01 00, or equivalent, between fan clutch and pulley.
4. Remove fan clutch attaching screw, then remove fan assembly.
5. Reverse procedure to install. Torque fan clutch attaching screw to 33 ft. lbs.
Check out the images (below). Let us know what happens and please upload pictures or videos of the problem.
Images (Click to enlarge)
Dec 26, 2022 at 3:09 AM
