loud bang from front drivers side and now rattle noise
2008 MITSUBISHI COLT
38,000 MILES
DDJANDERS
i was driving when i heard a massive loud bang from front drivers side and now i hear rattle noise when i go over bumps over 20mph what could it be?? So i have checked under the bonnet and cant see anything, checked under the car and cant not see anything. I think it may be coming from the front drivers side. Nothing obvious but could be suspension.
Jun 25, 2013 at 5:00 AM
KHLOW2008
  • 41,814 POSTS
Something is loose, worn or broken and if you perform a closer inspection, you should be able to see if. Most probably something to do with the suspension system and the stabilizer links are common failurre areas.
Jun 25, 2013 at 5:47 AM
