Loud clunk steering wheel feels like it is binding up?
145,065 MILES • 1.5L • AUTOMATIC
LILNIGHTMARE
OK, so about a week ago or so started having an issue with my car where if I am driving and I have to make a turn if I turn the wheel too far, Tim making a circle or whatever the steering wheel feels like it is binding up until I turn it the opposite direction enough that it makes a loud clunking noise and the brake pedal goes down to the ground for a split second brake pedal recovers to normal and steering goes back to normal but for the life of me, I cannot figure out what is causing the issue. I’ve been up under the car. Nothing looks broken and I just I am at a loss so any help you can give me would be greatly appreciated.
Jul 16, 2026 at 9:47 PM
MECHTRIX
  • 583 POSTS
warning do not drive the vehicle till the problem is resolved the brakes and steering are two different hydraulic systems ...therefore two different problems it needs to be towed into a shop with a lift to be properly inspected for any leaky bent broken parts that's the best I can tell you at this point ...its in a dangerous state right now and shouldn't be driven till fully repaired good luck be safe.
Jul 17, 2026 at 4:39 PM
