Lots of exhaust blue smoke
185,000 MILES • 2.3L • 4 CYL • 2WD • MANUAL
M. DEE
Power seems okay blue smoke (always) cold, hot idle,and run down the street (lots off almost like a sea foam treatment) . Spark plugs has carbon cylinder 4 spark plug pretty dirty (black)
compression good psi: cyl 1=210 ,cyl 2=205,cyl 3=185 after adding oil to spark plug hole =205 psi, cylinder 4 205 --(compression tester gauge might be a little off maybe to high.) new PCV valve,new ignition module.
1.Could this me a bad/plugged crankcase ventilation system,oil separator?
2. piston rings.
3. Valve seal or worn valve guides.
Help please
Oct 15, 2019 at 3:39 PM
SCGRANTURISMO
  • 4,897 POSTS
Yes. Yes. And yes. Blue smoke coming from your exhaust is a definite sign of oil being burnt in your combustion chamber. I don't think it is going to be from your vehicle's oil rings, valves, or a head gasket leaking though, that is a good compression test. I would start with the PCV valve. Anyway here is a link that you might find helpful below:
https://www.2carpros.com/articles/blue-smoke-from-engines-exhaust
Please go through this guide and get back to us with what you are able to find out.
Thanks,
Alex
2CarPros
Oct 15, 2019 at 9:36 PM
