have all gears except reverse..what would be the problem?
Jul 30, 2017 at 5:20 AM
HMAC300
✓Experienced Mechanic
many problems can cause this; low fluid for one, or a transmission range switch, but scan for codes it may also be either the seal is bad on low/reverse drum or clutch plates worn out shift in 1 and see if it will move. if not have a transmission guy look at it. See link. https://www.2carpros.com/articles/automatic-transmission-problems
Jul 30, 2017 at 7:23 AM
