no? reverse
100,000 MILES • 6 CYL • 2WD • AUTOMATIC
LATACEKA PITCHFORD
have all gears except reverse..what would be the problem?
Jul 30, 2017 at 5:20 AM
HMAC300
  • 48,601 POSTS
many problems can cause this; low fluid for one, or a transmission range switch, but scan for codes it may also be either the seal is bad on low/reverse drum or clutch plates worn out shift in 1 and see if it will move. if not have a transmission guy look at it. See link.
Jul 30, 2017 at 7:23 AM
