lost most electrical functions
150,000 MILES • 5.7L • V8 • 4WD • AUTOMATIC
GAIL GOTTSCHALK ALFT
Hi, My trucks headlights and dome lights work, but nothing else. no dash lights, no starter, no taillights. I did find a wire by the starter that was bare and on the heat shield, fixed it but that did not fix the problem.
Nov 21, 2019 at 8:36 AM
  • 110,248 POSTS
What color was the wire and could you tell what it was going to? If it was shorted, did you check fuses?
Do me a favor. On the left lower side of the dash is the fuse block. I attached a pic below and highlighted specific fuses that I need you to check. Do this and let me know what you find. The first pic is just showing where the fuse block is located.
Here are a few links you may find helpful:
______________________________________________________________
Let me know if this helps and what you find. Also, let me know as much as possible regarding the wire you fixed.
Nov 21, 2019 at 10:19 AM
the wire is purple and it was the small wire attached to the starter. I used my tester and there is no power to fuse box, which is confusing because the head lights and dome lights work. I even filed to bare metal to make sure tester was grounded good.
Nov 21, 2019 at 10:27 AM
  • 110,248 POSTS
Okay. That is the solenoid wire (s terminal). It should only have power when the key is in the start position.
Here is what I need you to check. There are two fusible links from the battery that may have failed due to the short. A fusible link looks like a regular wire, but is designed to function as a fuse. When they fail, they need replaced.
If you look at the pic I attached, check to see if power is making its way through the fusible links I circled. I also circled a 5 amp crank fuse located in the vehicle, but that isn't what is causing everything to not work.
Do this and let me know what you find. Simply check for 12v at the end of the fusible links (opposite side of the batter).
Nov 21, 2019 at 12:13 PM
