Vehicle seems to be idling low at times in park
2009 DODGE JOURNEY
98,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
RLAWSON21
However, if I put the car in gear, either drive or reverse, it stalls. Recently replaced all coil packs, plugs and wires. Also the battery because the winter weather trashed the previous.
I would greatly appreciate any direction.
Jun 10, 2019 at 11:55 AM
CARADIODOC
  • 34,368 POSTS
The clue is the battery was disconnected. Go out and drive the vehicle at highway speed with the engine warmed up, then coast for at least seven seconds without touching the pedals. That will meet all the conditions that must be met for "minimum throttle" to be relearned, then the computer will know when it has to in control of idle speed.
Jun 10, 2019 at 1:00 PM
RLAWSON21
Thank you for the quick response. I will try this as soon as possible. However I have used the vehicle without issue prior for about two weeks. I’ll provide update after relearning the throttle.
Thank you again!
Jun 10, 2019 at 1:18 PM
