Is there a way I can turn off the immobilizer system with the unlock key in the door?
150,990 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
COYSTOY
Lost the chipped key but I have the unlock is there a way I can turn off the immobilizer system with the unlock key in the door.
Feb 19, 2024 at 1:23 PM
STEVE W.
  • 15,411 POSTS
No. The emergency key only unlocks the doors. Without the transponder chip the immobilizer cannot be turned off. A mobile locksmith can replace the keys and erase the old ones, so they won't be a liability. A dealer can as well but a smith is usually cheaper.
This is the method used.
1. Turn the ignition on (transmission in park/neutral).
2. Use the DRBIII and select THEFT ALARM, SKIM, then MISCELLANEOUS.
3. Select PROGRAM IGNITION KEYS.
4. Enter secured access mode by entering the vehicle four-digit PIN.
Follow the on tool instructions to program the keys into the system.
Feb 20, 2024 at 12:39 AM
