Transmission fluid in the radiator
150,000 MILES • 4.6L • V8 • 4WD • AUTOMATIC
CHASEALLAN18
My truck started getting overheated and I realized I had a radiator leak and then noticed transmission fluid in radiator.
Apr 2, 2019 at 2:17 AM
Good afternoon,
Transmission fluid in the radiator tells me the cooler has failed.
You need to replace the radiator, flush the cooling system completely and flush the transmission as well.
As far as the chains, that is a separate issue. Can you upload a video of the noise that was described as the chains?
Apr 2, 2019 at 2:26 AM
Transmission fluid in the radiator tells me the cooler has failed.You need to replace the radiator, flush the cooling system completely and flush the transmission as well.
Roy I attached the procedure for replacing the radiator for you below.
https://www.2carpros.com/articles/how-to-replace-a-car-radiator
May 6, 2021 at 11:29 AM
