Lost
110,000 MILES
JOSDJOHNSON
My alternator went bad, so when I replaced it I also replaced the serpentine belt and spark plugs. After replacing these things the car will start but won't go above 1200 RPMS. So I bought an OBD2 Diagnostic Tool and was able to pull 2 codes, P2104 and P2112. From what I found on the internet theses codes mean, Throttle Actuator Control System - Forced Idle and Throttle Actuator Control System - Stuck Closed. I'm not sure what to do now. Any suggestions would be greatly appreciated.
Thank You
Apr 22, 2013 at 4:44 AM
DOCFIXIT
  • 18,828 POSTS
What engine? Have checked to see if a connector make have been disloged during work?Also was car jump started during this ALT failure?
Apr 22, 2013 at 5:04 AM
JOSDJOHNSON
It's the 2.3L. I checked over all connections and they all seem good. I did try jumpstarting it after replacing the alternator but it wouldn't start. I had to charge the battery over night.
Apr 22, 2013 at 5:07 AM
DOCFIXIT
  • 18,828 POSTS
Any chance polarity was crossed? chek all fuses especially underhood box
Apr 22, 2013 at 5:54 AM
JOSDJOHNSON
I actually just checked every fuse I could find and they are all OK.
Apr 22, 2013 at 5:56 AM
DOCFIXIT
  • 18,828 POSTS
Going to ask a friend that works for Ford when he gets home tonight see what ideas he has.
Apr 22, 2013 at 6:06 AM
DOCFIXIT
  • 18,828 POSTS
Got him on phone said most likely something binding throttle cable or vacuum to IMRC off
Apr 22, 2013 at 6:18 AM
