Loss power
109,000 MILES
ISMAIL1
Hi I have a ve golf gt tdi when I accelerate the power seems to go and black smoke appear then when I switch engine off and back on the power seems to come back then after driving for a bit it then seems to happen again. Any ideas.
May 3, 2013 at 7:49 AM
sounds like either a fuel problem or the injectors need cleaning or replacements
May 3, 2013 at 11:59 PM
EXOVCDS
  • 1,882 POSTS
The ECM is cutting boost (air) due to "overboost" detection. Once you turn it off and back on, things are find until the ECM detects too much
boost again.
This is a common problem due to carbon build-up in a couple of places.
Thomas
May 4, 2013 at 5:35 AM
ISMAIL1
I have got these cleaned out but also changed new oil filter.. Someone sec it would be the actuator that needs changing and someone said boost pressure switch please could anyone help? And how much it would be. Thanks
May 4, 2013 at 5:41 AM
EXOVCDS
  • 1,882 POSTS
I am no longer getting emails telling me that someone has replied to a topic... you will have to rely on the experts then.
Thomas
May 5, 2013 at 2:45 AM
EXOVCDS
  • 1,882 POSTS
The experts must be busy...
May 7, 2013 at 12:45 PM
