Loss of power to the throttle?
200,000 MILES • 3.5L • V6 • 2WD • AUTOMATIC
DBRADLEY1998
This weekend alone I've replaced the cam and crankshaft sensors, alternator, starter, and throttle body. It starts up first try until engine gets hot then shuts off Rev limit goes to around 4,000 RPMs and acceleration has low power. any help is appreciated. my next guess is fuel pump and filter.
Jun 26, 2023 at 12:57 PM
  • 110,248 POSTS
Wow, you have already done a lot. Have any of the things you've done made a difference? Also, when it shuts off, does it restart right away, or do you have to wait?
Anytime there is a loss of power, as described, I think of a plugged or partially plugged catalytic converter. Have you noticed any rattling from under the vehicle or strange sounds or odors from the exhaust? Take a look at this link and let me know if you feel anything mirrors what you experience:
https://www.2carpros.com/articles/bad-catalytic-converter-symptoms
As far as the fuel pump is concerned, before I would go to the trouble of replacing it and the filter, I would recommend checking fuel pressure.
Here is a link that explains how it's done:
You will need a fuel pressure gauge to do this, but if you don't have one, most parts stores will lend one to you. Also, I attached the manufacturer's fuel pressure specifications below.
See pic below.
Jun 26, 2023 at 4:30 PM
DBRADLEY1998
Could it possibly be something with the key fob like a drained battery in the key itself?
Jun 28, 2023 at 7:13 AM
  • 110,248 POSTS
If the key fob was damaged, it wouldn't start. It would set the immobilizer and prevent it from starting.
I went over your first post again. The idea that the engine RPMs won't go higher than 4K is interesting. When you reach that point, does it feel like a rev limiter has been reached or does it just won't go higher? I'm wondering if there is a timing issue.
joe
Jun 28, 2023 at 1:57 PM
