car starts and run ok until engine has warmed up, then i get major loss of power engine still runs but no revs when gas pedal is pressed down, i have to turn engine off, wait about 30 seconds then restart engine and car runs ok again for about 1 to 2 mins.
I have removed and cleaned the camshaft sensor and i have replaced the pre cat lambda(o2) sensor, should i also replace the post cat lambda sensor as well? or the coil packs, its such a tricky problem to pin down and repair
Jun 13, 2014 at 3:21 AM
