Loss of power on hills and under load?
2008 VAUXHALL MERIVA
100,000 MILES • 1.6L • 4 CYL • 2WD • MANUAL
SPARKY_75
Vehicle starts fine; idles fine.
No Engine Fault Codes in ECU.
Pulling off from a stop, there is a lack of power.
On hills, revs will drop, and power will drop away.
Have replaced:
* Spark Plugs
* Air Filter
* EGR Valve
* Fuel Pump and Filter
Cleaned throttle body and MAP sensor.
Stuck for ideas!
Mar 13, 2023 at 2:09 AM
  • 110,240 POSTS
First, please understand this vehicle isn't offered in the US, so my information is very limited. However, I will try my best to help.
Based on your description and what you have already done, the first thing that comes to mind is a partially plugged catalytic converter. If there is a restriction in the exhaust, it will create too much back pressure and cause a power loss or even prevent the engine from running.
Take a look through this link and let me know if anything mirrors what you experience:
https://www.2carpros.com/articles/bad-catalytic-converter-symptoms
Mar 13, 2023 at 1:56 PM
SPARKY_75
Thanks for the reply and information - it is much appreciated and very helpful.
There is no Check Engine Light illuminated; and I have tried 3 different scanners - which show there are no Error Codes.
I think you may be correct, and it is likely to be a blocked Catalytic Converter/Exhaust.
I will carry out some tests today.
Mar 13, 2023 at 5:01 PM
  • 110,240 POSTS
It's very possible. If you have a chance, let me know what you find. Also, here is a link you may find helpful:
https://www.2carpros.com/articles/how-to-test-a-catalytic-converter
Mar 14, 2023 at 8:23 AM
