Loss of power, shutting off
2013 VAUXHALL CORSA
55,000 MILES • 1.2L • 2WD • MANUAL
MISSEY123
Driving for 5 minutes or so start to lose power and car shuts off and will not start again. Sometimes starts after a while. Had breakdown service to it not showing any fault codes, fuel getting through etc., even they at a loss. Told could be ECU, changed it still the same , put new battery on, same. Seems like no one got the answer, just at a loss.
Nov 1, 2020 at 9:45 AM
  • CAR REPAIR CONTRIBUTOR
  • 110,190 POSTS
First, this vehicle isn't offered in the US, so my technical information is very limited. However, I will try my best to help.
When it doesn't start, have you checked to see if there is spark to the plugs? If you haven't here is a link that shows how to check:
If there is no spark, there is a chance the problem is related to the crankshaft position sensor. When these sensors start going bad, heat affects them. Once they cool off, they start working again.
Take a look through this link and let me know if it seems to mirror what you experience:
If it seems to mirror what you experience, here is a link that shows in general how one is replaced:
When I question one of these, I use a live data scan tool to see if there is an RPM signal when cranking. No signal usually indicates a bad sensor.
Nov 1, 2020 at 4:48 PM
