Loss of power after driving for about thirty to forty minutes
226,000 MILES • 2.4L • 4 CYL • 2WD • MANUAL
DUNCANTHEONE
Runs and idles fine, but after about 30 to 40 minutes on the road it starts bogging down like its losing power. After driving it and having that issue I can stop and rev it up with no issues whatsoever.
Dec 15, 2021 at 4:41 AM
  • 110,248 POSTS
It sounds like there could be an issue with fuel pressure or even a plugged fuel filter.
When this happens, is there anything that seems different? For example, do you notice the exhaust having a different odor, or see smoke from the exhaust? Is there any rattling in the exhaust? Is there anything that seems to prompt it to happen? For example, climbing a long hill.
If the fuel filter has never been changed, it would be a good idea to do it. It may or may not be the issue, but it is basic maintenance. If you look at the pics below, it shows the location. Pics 2-4 are the directions for removal and replacement.
Next, it would be a good idea to see if there are diagnostic trouble codes stored that may indicate where the issues are coming from. This truck has an OBD1 system and doesn't require a scan tool to retrieve codes. Follow the directions in this link and let me know if you find codes and what they are.
https://www.2carpros.com/articles/mitsubishi-trouble-code-definitions-and-retrieval-procedure-for-odb1-system
You will need a voltmeter or multimeter for the test. It's really easy to do.
Let me know what you find. If this doesn't help, we'll continue checking.
Dec 15, 2021 at 11:44 AM
