Loss of engine power
2000 NISSAN MAXIMA
155,000 MILES • 3.0L • V6 • 2WD • AUTOMATIC
MOE0000
Car won't go past 20 miles per hour extreme loss of power and hesitate.
Sep 26, 2020 at 11:51 PM
Good morning,
This could be from a couple of things.
https://www.2carpros.com/articles/engine-has-low-power-output
A clogged catalytic converter will not allow the engine to breathe and will cause no power.
https://www.2carpros.com/articles/bad-catalytic-converter-symptoms
Low pressure from a weak fuel pump is another common issue for this. Check the fuel pressure.
Sep 27, 2020 at 12:04 AM
