however there is now a huge power loss. No check engine light?
93,000 MILES • 6.2L • V8 • TURBO • 4WD • AUTOMATIC
VONDAL
My truck has a Roush supercharger. I wrecked it a year ago and flipped it. Only body work was needed, however there is now a huge power loss. No check engine light. All plugs and wires changed. At a loss.
Dec 19, 2019 at 8:17 AM
SCGRANTURISMO
  • 4,897 POSTS
This could be a problem with the intake air tract leaking and not letting all of the air enter your engine. Also you might want to double check the air filter and Mass Air Flow sensor[MAF]/Intake Air Temperature[IAT] sensor and make sure that they are tight with no leaks.
This guide can help us find it
https://www.2carpros.com/articles/engine-has-low-power-output
and
https://www.2carpros.com/articles/symptoms-of-low-engine-power
Please get back to us with what you are able to find out and we can go from there, if necessary.
Thanks,
Alex
2CarPros
Jun 28, 2021 at 5:40 AM
