No get and go changedcam dist plugs and wires fuel pump and filter timing chain and gears
Sunday, January 10th, 2016 AT 8:14 PM
WRENCHTECH
MECHANIC
Check for a clogged Catalytic converter
SPONSORED LINKS
Monday, January 11th, 2016 AT 2:20 AM
ROLA
MEMBER
Don't haveone
Monday, January 11th, 2016 AT 6:47 AM
WRENCHTECH
MECHANIC
What's the compression on all cylinders?
Monday, January 11th, 2016 AT 6:54 AM
ROLA
MEMBER
Comp good on all cyl
Monday, January 11th, 2016 AT 3:33 PM
WRENCHTECH
MECHANIC
I need the actual compression readings.
SPONSORED LINKS
Monday, January 11th, 2016 AT 3:44 PM
ROLA
MEMBER
Could it be in transmission
Monday, January 11th, 2016 AT 4:15 PM
ROLA
MEMBER
Dont know exact numbers moter starts easy and reevs up in park likeit should but u try to power brake or take off its like something holding it back in R and D its slow about golng HELP.
Monday, January 11th, 2016 AT 4:45 PM
WRENCHTECH
MECHANIC
I can't help you any more.
Monday, January 11th, 2016 AT 5:11 PM
ROLA
MEMBER
One more question do on you think it could be transmission
