Loss of power
2014 FORD FIESTA
98,000 MILES • 1.0L • 3 CYL • TURBO • 2WD • MANUAL
JUAN LEG
When driving for a period of time at about 60-70 mph my car occasionally has a loss of power as though the turbo has been stolen. it becomes very sluggish and struggles to accelerate without dropping into third gear. However, if I pull over turn the car off and open the door to cut the power completely then start it up it works fine again for a few weeks. In total this has happened about six times in three months. No warning lights noises or smells coming from the engine. Any ideas?
Jul 9, 2019 at 10:28 PM
Good morning,
This sounds like a clogged catalytic converter. The converters break apart inside and sometimes the broken pieces clog the out of the converter causing a blockage resulting in a loss of power. The engine cannot breathe when that happens.
Jul 9, 2019 at 11:12 PM
JUAN LEG
Is that likely to go away for a time from just turning the car on and off again though?
Jul 9, 2019 at 11:36 PM
Yes, it could. The broken piece could move once the engine stops.
Jul 9, 2019 at 11:59 PM
JUAN LEG
Great! thanks, I will start there then.
Jul 10, 2019 at 12:01 AM
You are welcome.
Always glad to help.
Jul 10, 2019 at 12:13 AM
JUAN LEG
Just been reading up on this. It has been suggested that the failure of the catalytic converter would also lead to an eggy smell, and a drop in fuel economy and most likely an engine warning light. None of these are present in my car.
Jul 10, 2019 at 12:16 AM
Yes to all when it is that, bad but never a light. There is a 420 code for the precious metals that wear out but never one for being clogged.
Jul 10, 2019 at 12:20 AM
BMDOUBLE
  • 1,139 POSTS
The rotten egg smell is not always there with a catalytic converter failure. I've replaced lots of converters on Focus and Fiestas from P0420 code and intermittent loss of power, totally agree with Roy!
Jul 11, 2019 at 3:16 AM
