Loss of electrical power while driving
155,000 MILES • 4 CYL • 2WD • AUTOMATIC
MARNIE HARRISON LEJEUNE
My husband was driving the car and the headlights and dash lights were all flickering. I was driving and the car suddenly lost electrical power on the interstate for a few seconds then it came back. Everything in the car was reset like the battery had been disconnected. Battery is new and charged alternator is recently refurbished and not too long ago the water pump and radiator failed and over heated the car. Everything that failed has Been replaced, Mechanic says the engine runs great and transmission is good. What do I check now?
Nov 30, 2018 at 6:56 AM
Good evening,
A couple things come to mind.
Battery cables. They need to be clean and tight. If they are not, low voltage could result which is what it sounds like happened.
2. Charging system problem.The charging system needs to be checked. You need 14 to 14.5 volts. also, need to have for any AC voltage. If there is the alternator is no good.
3. Ignition switch. It is in common for all the systems that failed. It needs to be checked to see if the connector has any burned or loose pins.
Nov 30, 2018 at 7:15 AM
If this helps narrow it down, today the car was parked and off and did not have power to the locks or lights. I opened the hood and slammed it back shut and the alarm came on and power came back. Just a loose wire or cable somewhere? Should I just start by cleaning the battery cables?
Dec 2, 2018 at 12:07 PM
Correct. That would be a good start.
Dec 2, 2018 at 8:16 PM
