Loss of coolant
2001 PONTIAC SUNFIRE
180,000 MILES • 2.2L • 4 CYL • 2WD • AUTOMATIC
MISSING2
Could a bad water pump make the car have no heat and loose coolant?
Dec 23, 2018 at 5:30 AM
Good afternoon,
If it leaks and the coolant level drops, that will cause no heat.
https://www.2carpros.com/articles/symptoms-of-a-bad-water-pump
If the pump was not working correctly, then you would have other issues such as overheating.
https://www.2carpros.com/articles/water-pump
Dec 23, 2018 at 7:28 AM
