Loss of All power, car stalls.
144,670 MILES • 1.5L • 4 CYL • 2WD • AUTOMATIC
2001DAEWOO
2001 Daewoo, New Battery, new sensors. Power shuts off. Radio, lights, everything. Starts again after a while.
No warning, At red light. While moving. Just dies. It runs well outside of this. Oil leak. Oil level fine. Coolant fine. Just changed front tire arms and rack in pinion. Trans fluid. Any suggestions? Shutting off is dangerous, don't want to go car shopping, not yet. Help for my mechanic? He says Daewoo with out engine code is hard to fix. I also cant afford to have him 'guess'. Thanks
Dec 16, 2013 at 12:05 PM
SATURNTECH9
  • 30,869 POSTS
I have had cars with similar issues what I did was let the car run while I was moving tugging etc on the wire harnesses. Also checking connections at the fuses boxes etc its not a easy diagnosis. But with luck and determination they will find the issue.
Dec 16, 2013 at 12:29 PM
