Loss of acceleration
120,000 MILES • 2.0L • 4 CYL • 2WD • MANUAL
DILLAGAF69
My car doesn't have the get up and go anymore. it starts out fine in first gear the rpm's go over 3,000 and i shift and it wont let me get up to 50 by the time i hit fourth gear. When i put my foot to the floor it does not do anything. sometimes it will jerk like it wants to get power. what do i do?
Nov 14, 2019 at 9:26 PM
SCGRANTURISMO
  • 4,897 POSTS
Is your vehicle's Malfunction Indicator Lamp [MIL] or "check engine" lamp illuminated. If so, can you please pull the Direct Trouble Code [DTC] for me. Here is a link below if you are unsure how to do that:
Please get back to us with what you find out. We can go from there.
Thanks,
Alex
2CarPros
Nov 15, 2019 at 1:47 AM
DILLAGAF69
No, there isn't a code. the check engine light is not even on. that's the thing.
Nov 15, 2019 at 11:48 AM
SCGRANTURISMO
  • 4,897 POSTS
Hello again,
Okay, that's good. So this could be a problem with your vehicle's throttle body needing to be cleaned. As the throttle body moves and ingests air, the air has pollutants in it that over time leave a black tar like substance called coke on the inside of the throttle body that interferes with the Throttle Position Sensor[TPS] signal to the Power-train Control Module[PCM] and when the PCM gets confused it will go into "limp" mode to keep from damaging the engine, while letting you take it in to get serviced. Here is a link below explaining this better:
If everything checks out a okay with the throttle body then go to this link below.
https://www.2carpros.com/articles/engine-has-low-power-output
Please go through these guides and get back to us with what you are able to find out.
Thanks,
Alex
2CarPros
Nov 15, 2019 at 2:53 PM
DILLAGAF69
My car was a little loud but once the power loss it muffled like it i have single exhaust turned into a dual at the and there is only a converter in there. but it's not real loud and now that i have barely power it muffled like there's a normal exhaust in the throttle body is fine.
Nov 15, 2019 at 10:50 PM
SCGRANTURISMO
  • 4,897 POSTS
Okay, so this might be a plugged catalytic converter. Sometimes the honeycomb part a catalytic converter when damaged can fall off and restrict the flow of exhaust through the catalytic converter and choke the engine. Here is a link explaining what is going on, how to test it and how to fix it below:
https://www.2carpros.com/articles/how-to-test-a-catalytic-converter
https://www.2carpros.com/articles/catalytic-converter-replacement
Please go through these guides and get back to us with how everything turns out.
Thanks,
Alex
2CarPros
Nov 16, 2019 at 12:52 PM
