Loss of accelaration
168,000 MILES • 2.0L • 4 CYL • 2WD • MANUAL
ROBERTLEEPIERCE5
I take off in first gear and can put gas pedal to floor and it seems to big down until a certain point then it goes normal. It's the same for every gear. Also, I filled my tank up completely and drove maybe thirty miles and the next morning my gauge said I had half a tank. You would think if it leaked seven gallons of gas while sitting over night I would've noticed a smell of gas but I didn't. I just bought the car used and the previous owner had the wiring harness replaced due to wires catching fire. I am quite upset that none of this was mentioned before purchasing it. Please help. Thank you
Jan 12, 2019 at 5:37 PM
  • 110,248 POSTS
Wow. that is excessive. What I want you to do is start by checking fuel pump pressure to confirm the regulator is working. Here is a link that shows in general how it is done:
Here are the specs for your vehicle:
Deadhead Pressure 880 kpa (130 psi)
Regulated Pressure 338 kpa (49 psi)
Next, I need you to check for an engine vacuum leak.
Check these things and let me know what you find.
Jan 13, 2019 at 7:41 AM
