My car loses idle speed when I turn on the lights. The original lamps were 50 / 60 watt, they were replaced by others of 90/100 watt of power.
May 14, 2017 at 6:43 AM
HMAC300
✓Experienced Mechanic
check battery for clean terminal ends and replace belt and tension-er which are supposed to be replaced at 60,000 miles. it may not be charging enough at idle.
