Losing a small amount of water
147,000 MILES • V8 • 2WD • AUTOMATIC
JONSOLOW13
  • 133 POSTS
having trouble figuring out where the water is going. Car loses around three ounces/day if we drive the car in hot weather (live in FL) around 2 hours/day. None of the hoses are leaking, and we can't find any water on the ground.
Car definitely loses water. We haven't pressured up the system yet, but even so, we don't think we'll see the leak.
My friend, an amateur wrench, speculates that maybe one of the head gaskets has a tiny leak on the exhaust side.
It is really baffling. If we forget to check the water at least every other day, for say a month, the car can start overheating. We have never let the engine lock up, and the valves sound fine.
There is no oil in the water, no bubbling, no white smoke in the exhaust, car runs smooth (no missing). Any ideas?
Thanks,
Jon
May 20, 2022 at 9:41 AM
  • 110,251 POSTS
It could be a head gasket. Tell me; have you checked to make sure the radiator cap is holding pressure? If it isn't, it could allow coolant to slowly evaporate.
Also, it could be a head gasket issue as well. Take a look through this link and let me know if anything it discusses mirrors something you noticed:
May 20, 2022 at 3:04 PM
