Losing power
293,000 MILES • 4.0L • 6 CYL • 2WD • AUTOMATIC
DOUG BOBO
Runs good for a few blocks and then loses power, if I shut the engine off and then start it up it runs good for a couple of blocks then does it again.
Oct 10, 2018 at 3:45 AM
  • 110,251 POSTS
There are many things which can cause a power loss. Low fuel pressure, a plugged catalytic converter, weak ignition. If the check engine light is on, first I would scan the computer to get the diagnostic trouble codes. They can prove very beneficial. If it is not on, we have to eliminate things, one at a time. Here are some links that discuss ignition issues, fuel pressure issues, catalytic converter issues and how to check them. Since it happens after driving a short distance, I would start with fuel pressure. Here are the links:
https://www.2carpros.com/articles/bad-catalytic-converter-symptoms
https://www.2carpros.com/articles/how-to-test-a-catalytic-converter
Here is a link that discusses several reasons for low power. Take a look through it.
https://www.2carpros.com/articles/engine-has-low-power-output
Oct 10, 2018 at 11:46 AM
