Will not shift
231,587 MILES • 5.3L • 4 CYL • 2WD • AUTOMATIC
CORWIN 86
When I accelerate and get to 25 mph, it will not change gears.
Nov 26, 2018 at 12:33 AM
  • 110,248 POSTS
If the check engine light is on, the first thing you need to have done is scan the computer for trouble codes. That will guide us to what is causing the problem. Many things can cause it.
First, here is a video that shows how to check for trouble codes:
https://youtu.be/YV3TRZwer8k
Sounds like it is most likely a transmission issue, does the speedometer work?
read this guide on transmission issues, it will help
Nov 26, 2018 at 5:47 AM
CORWIN 86
My question was not answered.
Nov 27, 2018 at 9:38 AM
  • 55,746 POSTS
Does the speedometer work I think is the response Joe was looking for. It sounds like it could be the turbine speed sensor. Here is the location so you can check it out. Please run the codes as well.
Nov 27, 2018 at 10:21 AM
