Losing oil pressure at idle?
224,381 MILES • 4.3L • 6 CYL • 2WD • AUTOMATIC
DAWNLOVE
When I stop at a light the oil pressure gauge goes down.
Oct 28, 2022 at 3:08 AM
  • 55,746 POSTS
This could be normal, how low does it go? The engine oil pressure will be lower at idle because the engine is not running as fast. If the oil had not been changed recently, I would do that with a heavier weight oil and new filter. Does the engine make a rattle noise at idle?
Oct 29, 2022 at 4:57 AM
