The EGR is not related to this problem. It is monitored and problems are detected while the engine is running. None of the failures will cause the engine to stall.
I'm not an expert on any scanner other than the Chrysler DRB3 that I use for my vehicles. That one lists the optional circuits in use on the vehicle it's currently connected to, and if one is missing, it won't display any codes that might be set related to it. The older DRB2 would ask you, for example, if the car has air conditioning. If you answer "No", it will not display the code for open compressor clutch relay circuit. If you answer, "Yes", it will display that code on cars that don't have AC.
The engine numbers don't mean anything to me, but they might to the people in the dealer's parts department. One thing I CAN offer is if someone did replace the engine, AND the flex plate, and the engine never ran after that, you likely have the wrong flex plate. I don't know if this applies to the V-10 engines, but it is a common sore point with the V-8s. Some of them have four groups of four square notches in the ring welded to the flex plate. The crankshaft position sensor sees those notches by generating a voltage each time a notch passes by it and disturbs its magnetic field. The Engine Computer needs to see four pulses, a gap, four pulses, a gap, . . . to know when to fire an injector and a pair of spark plugs, (one ignition coil), and it needs a different signal to know WHEN to fire which coil and injector. That is normally known by the signal from the camshaft position sensor. The first spark plug will fire once a signal is received from both sensors.
A different variation, (this is from memory and will likely be wrong, but you'll get the idea), has four notches in the ring on the flex plate, a gap, four notches, a gap, four notches, a gap, then five notches. When the computer sees five pulses in a row, it knows when a specific piston is coming to top dead center, and it knows which ignition coil to fire. From then on, it calculates which ones come next and just fires them in order each time it sees four pulses. The clue here is the engine will crank but will not start until that series of five pulses arrives. That can make it appear the engine has a long crank time before starting compared to what some people are used to.
The clinker is those flex plates can be interchanged. That often happens when an engine from a different year is transplanted and the flex plate stays with it. You need to reuse the flex plate that came with the truck. I don't know how many variations there are for these flex plates. but you can be sure you have the right one if the engine ever ran. Using the wrong flex plate always results in a crank / no-start condition. That would be frustrating to have to repeat the repair procedure to replace it, but it would be interesting first to watch the voltage on the dark green / orange wire to see if the ASD relay is being turned on sporadically by the Engine Computer. I don't plan on testing that idea any time soon!
Oct 4, 2018 at 3:32 AM
