Truck started running rough. Low on coolant so added more, started smoking white. No milky substance anywhere, I still need to pull plugs. Check them for milky substance and compression. Noticed oil level high so drained oil and coolant was found. If I have good compression and no milky substance on plugs, what do I check next?
Dec 28, 2018 at 6:09 AM
