losing clucth/brake fluid wich causing the clucth to go not enabling to change gear
2004 VAUXHALL ZAFIRA
2.0L • TURBO • MANUAL
NAYLOR123
i am losing fluid somwhere? when we top fluid back up the clucth and car works a dream but when fluid out there is no clucth? i have had a look around engine and can see fluid all over bottom, but i can not see where the leak is orignating from?
Jun 3, 2014 at 4:33 AM
  • 110,240 POSTS
There are 3 things that can leak, the clutch master cylinder (where you add fluid), the hose itself, or the slave cylinder which is on the transmission and is what disengages the clutch.
Jun 3, 2014 at 4:38 AM
