Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Chevrolet
Trax
Engine Cooling
Leak
Losing antifreeze
2015 CHEVROLET TRAX
140,000 MILES • 0.6L • 4 CYL • TURBO • AUTOMATIC
ADAMARSHALLO
MEMBER
1 POST
Keep losing antifreeze replaced cap still losing fluid.
Jul 26, 2020 at 9:08 AM
Experienced Mechanic
Good evening,
You need to pressure test the system to determine the area where it is leaking.
https://www.2carpros.com/articles/radiator-pressure-test
You can rent a tester and see where the leak is located. Once you see the leak, take some pictures and upload them here for me to see.
https://www.2carpros.com/articles/car-is-leaking-coolant
Jul 26, 2020 at 10:11 AM
Add image or video
Ask a new question
Engine Cooling — Leak
Check engine light
