Okay so I'm hopeless about my car. I have the car listed above SE model. Not supercharged. Originally the engine would turn on and it would start but then shut off after a couple seconds. Then I changed the EGR valve and the Mass Airflow sensor, and spark plug wires and it would run for longer and stay idling. But when I put it into gear it would shut off and backfire. Then I changed the spark plugs because the scanner was throwing a random cylinder misfire, which was I assumed to be spark plugs because I just replaced the coils and the wires and everything. Now I try to start it and it's back to square one. Shuts off right away and backfires. I've put over $350.00 into this thing to fix it and I still can't figure it out.
Jun 12, 2019 at 5:58 PM
