loses power while preseing on gas rpms go up and down then stalls no engine light
130,000 MILES • 4.5L • 4 CYL • FWD • AUTOMATIC
JONGATHOME
I have a nissan altima 2000 4cyl. I ccantfigure out whats wrong with the car. This issue has progressivly gotten worse to the point now i cant safely drive car. I start driving and randomly the gas loses power when i press on it it wont do anything then the rpms will zoom up and down. And eventually stall out. I have to keep tryi mg g o pump the gas until it will actually work. It will also sputter alot while driving and if i leave it idle.
I have cleaned the throttle body change the idle air control valve and the throttle position sensor and the wires and plugs for it. I have changed my fuel fulter and spark plugs. I have no idea what this could be it is getting very expensive. Any ideas?
Apr 18, 2015 at 8:01 AM
HOMER1967
  • 875 POSTS
is there any check engine light on?
Apr 18, 2015 at 1:26 PM
JONGATHOME
No. I wish
Apr 18, 2015 at 10:12 PM
HOMER1967
  • 875 POSTS
it could be so many things.i would suspect either a clogged cat. converter or a low fuel pressure issue.
Apr 19, 2015 at 10:07 AM
