Loses power when put into gear but idles perfectly
190,000 MILES • 5.4L • V8 • 4WD • AUTOMATIC
GREG FRAGODT
Loses power (hesitates badly) when put into gear trying to move forward, but idles perfectly. If I was describing the problem on a Chevrolet it would be the vacuum advance line was disconnected. Any ideas where the equivalent on a Ford 5.4 Liter, Triton would be? Could it be a possible fuse issue?
Aug 26, 2018 at 8:59 AM
Good morning.
No, that was a long time ago. Those days are gone. timing is done through the PCM.
No to the fuse.
With low power, the first thing I always look at is filters. Check the air and fuel filter, in fact, replace them.
Beyond that, I would check the fuel pressure to be sure there is enough pressure to run the injector needs for fueling the engine.
Catatlytic converters being clogged are a possibility as well.
Are there any codes stored?
https://www.2carpros.com/articles/engine-has-low-power-output
https://www.2carpros.com/articles/how-to-test-a-catalytic-converter
Aug 26, 2018 at 7:54 PM
