When car warms up and you come to a stop car acts like it was in neutral
169,000 MILES • 1.6L • 4 CYL • 2WD • AUTOMATIC
ALEX8304
Got a code on my car P0715 that indicates that is the turbine speed sensor and I can’t locate it. please help me.
Mar 6, 2019 at 12:59 AM
  • 110,251 POSTS
Welcome to 2CarPros.
The code doesn't always mean there is a problem with the main shaft or counter shaft speed sensor. It could be a wiring problem, connection issue, or an internal transmission problem.
Picture 1 shows the location of both aforementioned sensors.
Before replacing one of them, confirm that there is no corrosion at the plug and the wiring seems to be in good condition. Also, make sure transmission fluid is clean and full.
Take care and let me know if you have other questions.
Mar 6, 2019 at 6:03 AM
ALEX8304
Thank you for your help, I’ll check it out.
Mar 6, 2019 at 7:48 AM
  • 110,251 POSTS
Not a problem. Let me know what you find.
Mar 6, 2019 at 11:46 AM
