Loses power up hills
212,680 MILES • 1.6L • 4 CYL • 2WD • MANUAL
TEAL200SXSE
I do have one other question. When I bought the car it had a power problem when I got up hill it loses power and when I try to take off in first gear it feel like it wants to shut off and it's real sluggish. Can you help?
Mar 3, 2021 at 9:38 AM
  • 110,248 POSTS
The idea that it loses power and nearly stalls when starting out could be a few things. Low fuel pressure, engine vacuum leaks, a partially plugged catalytic converter can all cause these symptoms.
Here is what I suggest. First, check for diagnostic trouble codes. This vehicle has an OBD2 diagnostic system that can be scanned to retrieve codes. This will point us in the right direction.
Here is a quick video showing how it's done;
https://youtu.be/b2IJGfImVvw
Start with that and let me know what or if anything is retrieved.
Take care and God Bless,
Mar 4, 2021 at 5:54 AM
