Loses power sitters stalls while driving
240,000 MILES • 4.0L • V6 • 4WD • AUTOMATIC
BRANDYNORMAN
Loses power stalls trays to die, replaced the catalytic converter, fuel filter, and idle sensor control or ISC. Flashed the codes got a 412 so replaced that part. Flashed them after and got 111 all pass. Still having same issue
Sep 16, 2020 at 2:01 PM
Good morning,
Did you test the actual fuel pressure to be sure the pressure is correct?
https://www.2carpros.com/articles/engine-stalls
https://www.2carpros.com/articles/engine-has-low-power-output
What did you replace for the 412 code?
I would start with the fuel pressure test as you may have a bad fuel pump.
Sep 16, 2020 at 10:30 PM
