Loses power
152,000 MILES • 3.8L • V8 • 2WD • AUTOMATIC
GARRETT3185
The car runs smooth for awhile and then loses power and starts rumbling. There is smoke or fog coming out of the exhaust pipe.
Oct 23, 2017 at 3:09 AM
  • 55,691 POSTS
It sounds like the fuel pump is going bad. HEre is a guide to help you confirm the problem.
Fuel pressure should be between 45 and 55 psi.
If you confirm the problem and the fuel pump needs to be replaced here is a guide to help you see what you are in for when doing the job.
https://www.2carpros.com/articles/how-to-replace-an-electric-fuel-pump
Cheers, Ken
Oct 25, 2017 at 9:06 AM
