Loses power
220,000 MILES • 5.7L • V8 • 4WD • AUTOMATIC
CROYBOY
When holding throttle at a constant speed the engine will lose power then return constantly.
Nov 29, 2019 at 2:12 AM
AL514
  • 5,700 POSTS
Hello, does the check engine light come on when the problem is present? A good start would be to see if fuel pressure is dropping off at higher RPM's. Here is a quick guide to understanding fuel pressure testing:
Nov 29, 2019 at 4:03 AM
