Loose suspension parts
97,000 MILES • 4 CYL • TURBO • 2WD • MANUAL
NASER NASER
  • 836 POSTS
when jacking up both sides there is a movement on the 12 and 6 positions. I replaced inner and outer tie rods because i saw some play in them. now i am trying to figure out where this looseness is. only place i see it is in the wheel bearing. Does that make sense? And both front wheels are the sane way.
Dec 24, 2019 at 8:32 AM
  • 110,251 POSTS
It can be wheel bearings, however most times it is related to ball joints. I can't see them in the video. Have you checked them as well?
Dec 24, 2019 at 2:52 PM
NASER NASER
  • 836 POSTS
I did but I don't see any ball joint movement at all, all the movement is around the axle when I move the wheel, for both sides, not even a little bit around the ball joints.
Dec 26, 2019 at 7:23 AM
  • 110,251 POSTS
If that is the case, then it sounds like the wheel bearings. Here are the directions for replacing the hub bearings on the front. The attached pictures correlate with the directions.
____________________________
2006 Mini Cooper S Convertible (R52) L4-1.6L SC (W11)
Replacing Bearings (Wheel Hub) for Front Wheel
Vehicle Steering and Suspension Wheels and Tires Wheel Bearing Service and Repair Removal and Replacement Front Axle Replacing Bearings (Wheel Hub) for Front Wheel
REPLACING BEARINGS (WHEEL HUB) FOR FRONT WHEEL
31 21 180 - Replacing bearings (wheel hub) for front wheel
pic 1
Release collar nut (1), press brake pedal to floor for this purpose.
Installation:
Replace collar nut.
Tightening torque, 31 60 2AZ .
Important!
Secure collar nut after tightening down on flattened area of drive shaft by peening.
Necessary preliminary tasks:
- Remove brake disk
- Remove wheel speed sensor
pic 2
Release screws (1) and remove bearings for front wheel.
Installation:
Tightening torque 31 21 2AZ .
Important!
Dec 26, 2019 at 10:08 AM
