Loose shift stick
233,000 MILES • 2.0L • 4 CYL • 2WD • MANUAL
REDWOOD1488
Shifts perfect but has tons of play while in gear.
Nov 25, 2017 at 4:37 AM
HARRY P
  • 2,292 POSTS
I would check where the shift linkage goes into the transmission. Sometimes they can get a little loose and cause this type of problem. Also, pull the boot around the shifter off and make sure everything is tight there too.
Let us know what you find.
Nov 25, 2017 at 10:16 AM
