Loose or play in steering wheel when turning steering wheel
153,000 MILES • 3.0L • V6 • 2WD • AUTOMATIC
MAILMD32217
  • 23 POSTS
Greetings 2CarPros,
When I make a right turn while driving to turn right onto a different street, the steering wheel has a little bit of play when the steering wheel is turned to the far right. I feel and hear something that is loose fitting from the front suspension. What is it likely to be and how should I diagnose and repair the part in question?
M D
Jul 28, 2019 at 12:31 PM
  • 55,694 POSTS
It sounds like you have an inner or outer tie rod end that is loose you must raise the front of the car safety.
https://www.2carpros.com/articles/jack-up-and-lift-your-car-safely
Then grasp the wheels and move them back and fourth to find the play. Use a flashlight, this guide may help:
https://www.2carpros.com/articles/steering-wheel-shakes-when-accelerating-or-braking
Jul 30, 2019 at 5:22 AM
