Stalls when accelerating
220,000 MILES • 4.7L • V8 • 2WD • AUTOMATIC
CHRISTOPHER DANET
2 days ago was sitting with engine idling and it started to look to shut off. I changed MAF but now I go down highway and when I mash gas it looks to stall.
Feb 28, 2020 at 6:32 AM
When you say it "looks" to stall, does it actually stall or just stumble?
If it is doing this at idle and wide open throttle, that sounds like fuel issues. I would suggest starting with getting fuel pressure to start.
I attached the range to of the fuel pressure spec. I would suggest testing this at key on engine off, idle, and then wide open throttle.
Feb 28, 2020 at 6:44 AM
