Looking to get a detailed description of doing the timing chain job
2008 SATURN VUE
130,000 MILES • 3.6L • V6 • 2WD • AUTOMATIC
ASBROWN12479
  • 6 POSTS
Timing chain broke. Replaced all bent valves. Getting ready to do the timing kit. Didn't know if anyone has a pretty detailed description of the job to help me out. I have watched the cloyes video just want to get all information that I can. Thanks
Dec 4, 2019 at 1:19 AM
Good afternoon,
I attached the Melling video for you.
https://www.youtube.com/watch?v=1SC8Jy9NOJk
Do you have the chains with the color links?
Do you have the cam locking tools for the cams?
Dec 4, 2019 at 5:42 AM
ASBROWN12479
  • 6 POSTS
Yes I do have the color links in my chains and I also have the cam locking tools.
Dec 4, 2019 at 5:55 AM
OK, just take your time and line everything up as the video suggests.
Dec 4, 2019 at 6:01 AM
ASBROWN12479
  • 6 POSTS
In the Cloyes video it has 1st stage and second stage. do I need to do that?
Dec 4, 2019 at 11:14 PM
Yes, you do. Follow the instructions on which chain gets installed first.
Dec 4, 2019 at 11:21 PM
ASBROWN12479
  • 6 POSTS
Okay, thank you.
Dec 5, 2019 at 1:02 AM
You are welcome.
Dec 5, 2019 at 1:10 AM
ASBROWN12479
  • 6 POSTS
Sorry I have another question. I had to remove the head because of bent valves. Reading the Haynes manual it tells me to tighten to only 22ft.lb plus additional 150 degrees. Does this seem low?
Dec 6, 2019 at 10:29 PM
What is that? Spec for the head?
Dec 7, 2019 at 12:41 AM
Okay, I hope it was a typing error.
I attached the specs for the head below.
Dec 7, 2019 at 12:47 AM
