What are the head bolt torque specs?
145,000 MILES • 1.5L • 4 CYL • 2WD • AUTOMATIC
JAMIE L
Head gasket was leaking oil to the outside.
Jan 8, 2025 at 7:45 AM
  • 110,248 POSTS
If you look below, I attached the directions for installing the head. Note: The directions (pic 2) provide the tightening sequence. Make sure to follow them.
Next, you have to do this in two steps. Once you have all the bolts installed, using the sequence provided, tighten the head bolts to 22 ft/lbs. Once that is done, you need to turn each bolt an additional 240° further.
Jan 8, 2025 at 11:58 AM
JAMIE L
Thanks a lot!!
Jan 8, 2025 at 6:11 PM
  • 110,248 POSTS
No problem whatsoever. I'm glad it helped.
Take care and feel free to come back anytime in the future.
Jan 9, 2025 at 10:51 AM
